Out drive corosion help >
Old 05-13-2007 | 08:25 PM
Default Out drive corosion help
A buddy of mine purchased a boat that was in salt water. It is an express crusier and the water pick up is in the outdrive. The saltwater did a number on the drives and started eating away at the aluminum.
The pick ups were caked with chalky crap, and he cleaned all that up, problem is the inner part of the drive seems to be a bit clogged because he is not getting good flow out of one of them. He plans to purchase new drives next year, but he is kinda low of funds so trying to get through the season. Any product out there that he can flush through his outdrive to clean that chalky crap out?
He flushed it with a garden hose and it improved the water flow out of the sea water pick up significantly, but flow is still less then the other side. Good news is, he has no water in his drive fluid so the problem is not too bad.
jvschlegel is offline
Old 05-13-2007 | 09:36 PM
Flush with Salt Away.
http://www.westmarine.com/webapp/wcs...key=SiteSearch
Griff is offline
Old 05-13-2007 | 11:21 PM
cuda's Avatar
It was probably stray electricity in the water from other boats around. I've seen signs of it after one night at the Hyatt in Sarasota.
cuda is offline
Old 05-14-2007 | 03:53 AM
cig1988's Avatar
Salt away definely works.
cig1988 is offline
Old 05-14-2007 | 08:33 AM
Thanks again guys for the speedy responses. Never a tough question for you all.
jon
Old 05-14-2007 | 12:18 PM
The Menace's Avatar
Salt Away will not flush away existing corrosion. It will prevent and deter corrosion.
The Menace is offline
Old 05-14-2007 | 12:57 PM
After reading, I see that. Any way to use some type of acid or something that works at the white chalky stuff that gets built up because of aluminum deterioration?
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
