raw water pickup question >
Old 05-21-2007 | 08:38 AM
Default raw water pickup question
i have a bravo 1 w/454, thru hull exhaust. towards mid summer we get alot of weed in the water. right now my pickups are the traditional ones in the outdrive. i would like to put a thru hull pickup in. can i just add a T and combine it with the outdrive pickup hose. if i do this ,do i have to change any hose sizes?
zane is offline
Old 05-21-2007 | 11:32 AM
you can just take the plastic fitting off the inner transom plate where the 1 1/4" hose is attached and put a block off. then put a 1 1/4' through hull ball valve in the bottom but on the outside you install a south bay strainer. your weed problem will be gone. you also need to cut the water hose on the outside bellhousing so that water can be forced through the drive to keep it cool. the second method would be to just cut the 1 1/4" hose coming into the boat and install a strainer but you will still need to clean it out from time to time.
lowfunds is offline
Old 05-21-2007 | 10:06 PM
monstaaa's Avatar
install a hardin marine sea strainer and be done with it. easy to use simple to install and it comes with a bung in it to use as a fresh water flush.
monstaaa is offline
lennyk
07-15-2008 07:19 PM
dualprop
09-11-2006 02:34 PM
Dangerous Dave
6
06-10-2005 07:14 AM
p4-33
6
07-15-2004 10:13 AM
BadDog
14
05-19-2003 04:18 PM
