Raw water pickup depth >
Old 06-08-2005 | 05:07 PM
Default Raw water pickup depth
I'm replacing the old merc through transom water pick ups on my boat with new stainless steel ones that need to be cut to the right depth. My question is, what is the right depth? How far below the bottom of the boat should they hang? should I cut them at an angle? It's an '85 Cigarette 28 w/ small blocks and TRS drives.
Dangerous Dave is offline
Old 06-08-2005 | 07:38 PM
monstaaa's Avatar
Default Re: Raw water pickup depth
they should be cut at a slight angle. as far as how much , maybe start a 3/4 of an inch run the boat, check water psi at w.o.t , then cut or trim accordingly
monstaaa is offline
Old 06-08-2005 | 09:32 PM
I think with the front edge even with the bottom the back edge should be at least 3/8'' lower to start.See what the water pressure is and trim as needed. Remember it is much eaiser to trim some off then to weld metal back on.
mmwalters is offline
Old 06-09-2005 | 07:24 AM
Official OSO boat whore
The best ones are the designs with a adjustable cutting edge. I have an adjustable one and I'm seeing 10psi at 3/16".
Cord is offline
Old 06-09-2005 | 10:04 AM
Since the water curls up off the bottom of the boat you don't need it as long as you would think.
zahndok is offline
Old 06-09-2005 | 03:39 PM
What is a good target for water psi? Would the fact that I have crossovers change anything? Thanks for the replies.
Dave
Old 06-10-2005 | 07:14 AM
The crossovers typically cause the engine to run cold. Keeping the pressure under 20psi is a good rule of thumb.
Cord is offline
LZH
Drives and Lower Units
0
02-25-2008 08:18 PM
zane
2
05-21-2007 10:06 PM
dualprop
09-11-2006 02:34 PM
p4-33
6
07-15-2004 10:13 AM
StrikinLightnin
5
08-15-2002 09:04 PM
