changing prop spin >
changing prop spin
changing prop spin
Old 05-28-2007 | 08:53 PM
tgersx's Avatar
Default changing prop spin
i want to change my props from spinning in to spinning out. right now i have huber 1450 trans with speedmaster 5's how do i go about doing this?
tgersx is offline
Old 05-29-2007 | 06:51 PM
RMPRam's Avatar
Either swap the complete drives or leave the uppers attached to the gimbles and just swap the lowers. You will have to drain the fluid from the drive before you "drop" the lowers and then refill. Watch the o-rings, if you choose to do this swap.
My recommendation is to swap the drives. The only "hard" part is getting the "donkey ****" to align into the transmission. Once you have done the swap several times, it's not that bad.
Let me know if I can be of any more help. I've got 2 sets of #3A's and one set of #5's. I've got spares.
RMPRam is offline
Old 05-29-2007 | 09:48 PM
http://www.mercuryracing.com/product...tunnelrace.php
osen007 is offline
Old 05-29-2007 | 11:11 PM
tgersx's Avatar
you cant just run the trans in reverse and change the cables at the helm and swap props? thats how i did it with my bravo drives
tgersx is offline
Old 05-29-2007 | 11:37 PM
No, the trans will not survive.
Griff is offline
Old 05-30-2007 | 05:44 AM
Pwrbt33's Avatar
definetely do not run the transmissions in reverse! Big NO NO! And what ever you do with the lowers, just make sure they stay in the rotation that they are set up for. Dont take the LH lower and spin it RH and vise versa. The spur gears on top of the lower are set up for what they are.
Bravos are a hole different animal. They are ampidextrious. SSM are not.
John
Pwrbt33 is offline
Old 05-30-2007 | 12:28 PM
tgersx's Avatar
thanks for the help!
tgersx is offline
Old 05-30-2007 | 01:46 PM
RMPRam's Avatar
All the uppers on the SSM drives rotate the same way, so changing just the lowers would not cause them to spin in a direction that they were not set-up to do.
RMPRam is offline
Old 05-30-2007 | 02:08 PM
RMPRam's Avatar
I just spoke with John (Pwrbt33) about his post. What he was refering to would be placing the drives behind a reverse rotation motor, so as to change the rotation of the uppers and the lowers. I've never run into a performance boat with a reverse rotation motor, so this swap (just the lowers) should not be a problem. Double check the rotation of your motors though.
Gary
RMPRam is offline
sierraspringsjay
3
05-27-2008 04:20 PM
JBoat
06-07-2007 06:10 PM
tgersx
Drives and Lower Units
1
05-29-2007 08:32 PM
tgersx
05-28-2007 05:28 PM
