What keeps the water out of ... >
Old 06-04-2007 | 07:39 AM
DORaymond's Avatar
Default What keeps the water out of ...
the u-joint, drive shaft area of a Bravo drive? Never thought about it until now, but I don't think there is a gasket or o-ring on the outdrive that seals that area. When a drive is installed we put a new o-ring on the water intake, shift cable, and lube monitor, but what seals the drive itself to the bell housing?
DORaymond is offline
Old 06-04-2007 | 07:57 AM
Hopefully you have a "drive bellows" in there somewhere!...
Bajapred is offline
Old 06-04-2007 | 09:50 AM
DORaymond's Avatar
Of course there is a drive bellows in there. Backup a couple of inches from the bellows, where the metal upper gear case meets the metal bell housing. There is not a gasket in that area.
Old 06-04-2007 | 10:30 AM
Mbam's Avatar
Offshoreonly Advertiser
It seals on the edge of the bellows
Mbam is offline
Old 06-04-2007 | 10:56 AM
DORaymond's Avatar
Mbam - thanks for the reply. That makes sense.
I know I can see an imprint on the end of the bellows from the drive. I have never heard of changing a bellows that is not torn because it does not seal properly to the installed drive - must not be an issue??
Old 06-05-2007 | 06:34 PM
ROUGH WATER's Avatar
it is an issue if that seal is not made at the end of the bellows it will let water in to the gimbal, if you can see a imprint that doesnt go away its probley no good, too old, just like a old oring, had the same problem on a 88 w bravos,
ROUGH WATER is offline
zimm17
8
07-10-2007 09:09 PM
MnHowardCat
7
05-29-2007 10:12 PM
waterbum
0
08-15-2005 10:36 AM
28Eliminator
11
06-22-2004 10:43 PM
Waterfoul
04-17-2003 08:01 PM
