How to set timing >
How to set timing
How to set timing
Old 06-10-2007 | 12:11 PM
Default How to set timing
Hi,
Need some help, i shall set the timing on my
Volvo penta 5,0GL -99.
I have all the info from volvo about the timing setings.
8 degree at 600 rpm and 31 degree at 4000 rpm.
But to be able to use a timing light and set initial timing i must first shut off the electric spark advance.
How will i do that?? Can i conect a hoop some where to get into service mode??
Imp Thomas is offline
Old 06-10-2007 | 12:34 PM
ls1nova's Avatar
The procedure from Merc is to bump the rpms up to 1200, then put it in service mode by shorting out pins A and B on the diagnostic plug. Then set base timing to 8 deg. Unplug the jumper and your done. I use half of a paper clip to short them.
You are going to want to verify that it's the same for Volvo, but the computer is the same so I would guess it is.
Frank
ls1nova is offline
Old 06-10-2007 | 01:03 PM
I dont have a diagnostic plug on this engine, its a carburetor with electric spark control, Volvo says i must use there timing test tool and plug it in the empty plug in the distrubuter, but they also said it work by shorting out two pins but they dident now which one.
Old 06-10-2007 | 01:27 PM
ls1nova's Avatar
oops, sorry, I was thinking efi.
ls1nova is offline
Old 06-10-2007 | 01:36 PM
That`s okey anybodyels that got some info?
Old 06-10-2007 | 02:46 PM
cuda's Avatar
Just run the rpm up to 4000, set the timing to 31*, and let the initial timing fall where it may.
cuda is offline
docmanrich37
1
04-16-2007 01:25 PM
Donman
1
09-28-2005 08:12 AM
baja36ft
1
05-25-2005 04:24 PM
baja36ft
2
05-10-2005 07:03 PM
Jayl13
18
06-29-2002 06:13 AM
