Boat Stereo ? >
Boat Stereo ?
Boat Stereo ?
Old 06-12-2007 | 03:19 PM
29KILROY's Avatar
Default Boat Stereo ?
I have a Sony Head Unit and when I turn it up more than half way it shuts off! I have run all new speaker wires, I have unplugged the Subs, and tried un plugging one speaker at a time and three work fine but as soon as you put all four on it shuts off. When I mean shut's off it still has power just now sound.
29KILROY is offline
Old 06-12-2007 | 03:24 PM
Tony Montana's Avatar
The BAD Guy
Are you running a amp to said speakers that shut off or are they run off head unit? Also how old is the install? Have you ever had this problem before now ?
Tony Montana is offline
Old 06-12-2007 | 03:26 PM
DPA
Your last speaker your connecting may be shorted. Try and conect the speakers in a different order to check. I had one that did the same thing in a car it was a sony too. You could have more than one bad speaker also. Im sure you have the polarity of the speakers correct?
DPA is offline
Old 06-12-2007 | 05:08 PM
I bet you have a bad battery
allenk4 is offline
Old 06-12-2007 | 05:50 PM
You have a dead speaker and your Sony head unit is not reading it properly.Find the dead speaker(s) and the problem is solved.The head unit is not the problem.
Prostreeter is offline
Old 06-12-2007 | 05:59 PM
BY U BOY's Avatar
If your running the speakers on an amp try upgrading the power wire and adding a cap.
BY U BOY is offline
Old 06-12-2007 | 07:22 PM
hunster's Avatar
Ohm meter the speakers! Should be 4 ohms. Sony amp sections are real picky and shut off quick to shorts. Put a multimeter on it and I'm sure you will find a bad speaker or a short. If they all meter 4 ohms at the radio plug then its the radio but again I'm sure you will find it in the speakers or the wire.
hunster is offline
Old 06-12-2007 | 07:26 PM
First problem sony i'm an audio nut and have had nothing but problems with sony products over the years.
Superboat502 is offline
Old 06-13-2007 | 05:23 AM
29KILROY's Avatar
Okay
-No amp on speakers, just an amp for subs. When I by pass the Subs it still shuts off
-All the speakers are working when I check them individually. I can run any combination of three without an issue, but when I hook up the fourth no matter what order it will shut down.
-Hunster am I checking them right on the posts where I am connecting the speaker wire? Also are they 4ohms all the time or only at a certain sound level?
-Prostreeter you are right, I swapped out the head unit with a totally diff. head unit with the same wiring harness and it shut off....
29KILROY is offline
Old 06-13-2007 | 05:28 AM
29KILROY's Avatar
THANKS for all of the help!!!
29KILROY is offline
Magnum25
03-12-2007 10:17 PM
Boomer35
03-01-2006 04:04 PM
Wardey
10-01-2005 05:28 PM
BigChief
12-09-2003 05:34 PM
jbrauer
03-09-2002 05:36 AM
