Vapor Lock?
Old 06-12-2007 | 04:32 PM
Default Vapor Lock?
Ok Guys...Help!
2000 Sea Ray with 5.7TBI engine. Boat start and runs fine. It will run all day at 170 degrees. Power at all rpm ranges is ok. When i drop anchor and sit for 30 minutes, the boat will not start., It has ignition, spark at plugs etc. If the boat sits for 60 to 90 minutes it will start and run fine. I called Marinemax and they told me this has become a common problem since ethanol was introduced last July. The fis is a booster pump in fuel line. Any one else having this problem and is a secondary pump the right fix? thanks
tbenza is offline
Old 06-13-2007 | 01:00 AM
handreasen's Avatar
Had same problem with elec fuel pump on my 500EFI.
discovered that armature was heat soaking in fuel pump and locking up. Replaced with new electric pump and issue is resolved.
handreasen is offline
Old 06-13-2007 | 11:03 AM
Dave_N's Avatar
Check out this Merc service bulletin. Some good info on vapor lock.
http://www.boatfix.com/merc/Bullet/99/99_07.pdf
Dave
Dave_N is offline
Old 06-14-2007 | 09:41 AM
Big Block Billy's Avatar
Post
Some more evidence that ethanol does not belong in marine fuel. You won't be finding it in AV Gas. This stuff is garbage. It is also leaning out engines due to the difference in it's stoichiometric air fuel ratio. BBB
Big Block Billy is offline
Old 06-14-2007 | 03:08 PM
Post
Reid vapor pressure @ 100 F PSI is 8-10 Gas
Only 2.3 in Ethanol
Latent heat of vaporization in Gas 900 BTU/Gal 150BTU/LB
" " ETHANOL 2378, 396 respectively.
Could this help explain it ? BBB
Brandon
5
08-18-2007 06:41 AM
LAXBAJA
5
06-27-2006 01:06 AM
dawiz74
1
04-19-2004 11:09 PM
Pure Energy
07-22-2002 11:56 AM
American Dreamer
2
06-03-2002 10:50 PM
