Need Help merc 2.4 >
Need Help merc 2.4
Need Help merc 2.4
Old 06-13-2007 | 04:20 PM
Default Need Help merc 2.4
I f uped an engine and trying to figure out what i did.
I took the heads off today and realized that the 1 and 6 pistons were cooked. the 6 has a hole in it and 1 is not much better. Not sure if those are the correct # so see my numbers below.
1 2
3 4
5 6
what would cause this?
I jave a new powerhead I plan to put on but wan't to avoid this from hapening again.
Please any help would be great
thanks
Josh
oldschoolfan is offline
Old 06-13-2007 | 09:17 PM
monstaaa's Avatar
remove the plate between the cyclynders. see if the long rubber strip is broken or crystalized. how much water press? and are you runing thermostats or restrictors? e.f.i or carb?
monstaaa is offline
Old 06-13-2007 | 09:49 PM
Default thanks
the rubber strip is still intact and flexible. the motor is a carb. and there are thermostats
josh
shw-n-go h20
8
07-29-2008 10:05 AM
Magic34
10-24-2007 05:05 PM
dfealy
11
09-21-2007 04:07 AM
superwrench0166
1
01-06-2007 08:59 AM
timucin
4
11-03-2002 07:29 PM
