Lower temp warning switch? >
Old 06-20-2007 | 12:30 PM
Default Lower temp warning switch?
Factory Merc alarm temp switch is supposedly 210? Has anybody found/used a 190? I don't remember the brand, but I found a 200 that's sold with a generic alarm kit.
I'm about to change t-stat housings so I figure it's a good time for new sending units and warning switches.
handfulz28 is offline
Old 06-20-2007 | 12:43 PM
Wobble's Avatar
SORE MEMBER
just about any speed shop will sell the switch in a variety of temps. You will want the normally open type. I'd agree that a 210 switch would be too high for a raw water cooled motor.
Wobble is offline
Old 06-20-2007 | 12:50 PM
Try summit or jegs. They carry set and adjustable temp sensor/switches.
rdoactive is offline
Old 06-20-2007 | 01:26 PM
No luck with the big names. Most are 210 or 230.
Found this though:
http://www.spalusa.com/fans/automate...ies/195ts.html
Stainless steel and even shows the Merc style ring terminal. Might be the ticket for $30.
Old 06-20-2007 | 01:53 PM
Ordered a pair of 195 and a 1/2 adapter for each. Should go nice with new stainless polished t-stat housings.
I'm not sure what the hysteresis is on the Merc switches, but on these it's 20 degrees. So the switch will close at 195 and won't open again (turn alarm off) until temp drops to 175.
stormbauer
Drives and Lower Units
4
09-18-2008 05:28 PM
bford1
9
04-13-2004 01:13 PM
racer-x6
2
05-15-2003 09:02 PM
formula31
4
09-30-2002 05:57 PM
formula31
8
02-07-2002 03:16 PM
