Should I switch to IMCO Lower? >
Old 09-14-2008 | 06:38 AM
Default Should I switch to IMCO Lower?
Current have Teague Uppers with what appear to be standard Bravo lowers with nose cones (not sure purchased like it is and cannot find out). Was looking at switching to IMCO lower with -1 or -2?
Want to dial my 1999 Daytona 33. What should I expect from this switch?
stormbauer is offline
Old 09-14-2008 | 10:42 AM
articfriends's Avatar
Buy the -2's,try them and space down IF neccesary. What you'll see depends alot on how high your x currently is,if you already have planing issues and have to run 5 blades then re-consider and check your prop c/l compared to some known combos on same hull as yours Smitty
articfriends is offline
Old 09-14-2008 | 04:40 PM
Running B1's and boat planes like a rocket. Will actual get on plane fairly easy also with one motor! Did not try on purpose.
I am also looking to run different props since, current cruise is way to high on RPM.
Old 09-14-2008 | 05:45 PM
I would be surprised if the "X" on a 1999 Eliminator was 2" low. Consider calling Eliminator and reviewing your current set up and see what they recommend.
BenPerfected is offline
Old 09-18-2008 | 05:28 PM
How can you find out where the standard X dimension should be?
Pure Energy
13
03-14-2008 10:39 PM
Back4More
Drives and Lower Units
1
01-15-2008 09:30 AM
handfulz28
4
06-20-2007 01:53 PM
Bob280Silencer
Powerquest
1
05-17-2004 07:11 AM
Cattitude
Pantera
1
09-13-2003 03:51 PM
