Help?  Bravo 1 Question >
Old 06-25-2007 | 05:01 PM
rip the center out of the prop hub ? had a big fountain here do that
stevesxm is offline
Old 06-25-2007 | 06:23 PM
it is not the prop had the rear cover off the drive and the cone clutch is not pushing down on the lower gear
rssteiny is offline
Old 06-26-2007 | 08:06 AM
now that i know it is a problem with the cone not pushing down on lower gear but works fine pushing up to upper gear and all gears and everything looks fine will i be able to get by this weekend going to and from party cove about 8 miles each way, if i reverse props and run in reverse on my controls, this way i will just not have reverse in 1 drive since b1s are bi rotational. then pull the drive next week and fix.
thanks
rssteiny is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
pax2you
3
09-18-2007 09:07 AM
xpx747
08-28-2006 03:55 PM
deboatmon
0
04-29-2004 02:24 PM
later
1
03-03-2004 09:13 PM
