454 out of a truck-work in a boat?
Thanks, thats a big help as Im not sure what year the engine is out of the truck yet. Ill have to see if I can get some stamping numbers and see what I can come up with. Do you know off hand if say the truck engine is a 90 or newer, it will be the same as my 92 engine?
Another way is the rear main seal. Gen IV has a 2 piece, Gen V a single piece.
A 1990 and 1992 block should be the same. Gen V production block are from 1990 to 1995.
Patrick
Patrick
Thanks Pat, thats a big help. Ive asked a few marina's and engine shops around here, and I cant really get a straight answer. Some say yes, no problem, others say completly different, wont work. So, I need to make sure the block is the same gen, and change pistons and cam. Other than that I should be good to go?
SORE MEMBER
1 Post
Get the casting numbers off both blocks and go here http://www.mortec.com/bbc.htm just about the last word on gm casting numbers, they have crank, head and intake numbers also
I'd say yes, if the blocks are the same Gen, new pistons, rings, bearings, cam, timing chain, oil pump, gaskets,..., and you should be good to go.
Good Luck with your project...
Patrick
Patrick
Thanks Pat, either way I look at it Im still going to be spending a chunk of change, so Im trying to figure the most economical way to do it. I guess Ill have to add it all up and see where the $ falls. Thanks for the help guys.
