Video with alignement tool >
Old 07-10-2007 | 08:31 PM
25 hors la loi's Avatar
Default Video with alignement tool
Ok guy ...what you think about this video...my friend have a vibration in back of is boat ...its possible to have a coupler wear ?? ...but the alignement slide real well inside the coupler ?? any advice ? have you seen this before ? ...we have to be prepared to remove the engine for exchange the coupler ?
Thanks to take time
25 hors la loi is offline
Old 07-10-2007 | 08:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Did you check the prop and prop shaft for out a round or bent blades?
Does it vibrates in both gear and in N?
US1 Fountain is offline
Old 07-10-2007 | 09:24 PM
U-joints? Gimbal Bearing?
1BIGJIM is offline
Old 07-10-2007 | 11:58 PM
I highly doubt its the coupler. Prop, propshaft, u-joints or gimbal bearing are the most likely causes.
Griff is offline
Old 07-11-2007 | 01:09 AM
J-Bonz's Avatar
1. check the gear lube for metal.
If metal then there ya go
2. if not check the prop spines and shaft
3. pull the drive(it has to come of anyways) and check the yoke, u-joints, and coupler.
4. check the gimbal bearing
5. you should find the problem by know
Jr.
J-Bonz is offline
Old 07-11-2007 | 07:40 AM
hoozeyurdaddy's Avatar
the bounce on that bar goes straight into the u-joints, would it vibrate, probably, i think you need a coupler.
hoozeyurdaddy is offline
Old 07-11-2007 | 09:23 AM
I think you are on the right diagnostic .....we try the same test on another boat this morning ...and the tool are much more stable ....
tomorow morning we going to take out the motor ...and check for the flywheel or the coupler ??? ... i will stay you informed on what we found
thank`s for all the input guy .....
Old 07-11-2007 | 10:24 AM
We had the same problem and it was the coupler, It has a alumiumn receiver and the teeth were so bad that they were
pointed, Get the one with a steel receiver.
Mike J.
Mike J is offline
Old 07-11-2007 | 05:10 PM
While it has never happened to me, it seems that if the engine was significantly out of alignment, this could happen as well. It's hard to imagine the coupler doing this on its own. Couplers usually get "spun" or wear out, but going out of round or somehow losing its center seems far fetched. Just my 2 cents
Rene
oldandtired is offline
Old 07-16-2007 | 10:55 AM
Mike J.
Yes it`s the coupler ....we exchange it this past week-end ...and every thing going well right now ...Thank`s to all of you
Regard`s
jayhawk261
Grand Lake/LOTO/E-Dock
0
04-07-2007 12:09 PM
racer-x6
05-19-2005 03:43 AM
Air Dog
05-12-2004 11:42 AM
SCOPEwebmaster
05-02-2002 02:14 PM
sheikman
8
03-01-2002 07:00 AM
