Slave Solenoid? >
Slave Solenoid?
Slave Solenoid?
Old 09-08-2021 | 06:38 PM
Default Help
Originally Posted by flashgordon
hello,,you sound like u are having same problem. starter just clicks?? i even jumped the starter solenoid and starter worked. i thought it was a ign switch, swapped switchs, then someone in here mentioned the slave soleniod. a new one to me, so mine was right next to distributor, bolted to panel with a large push button fuse. good purchased a couple tomorrow. i will post if that solves problem.
good luck.
what was the solution? I have the same problem
Brian Nun Ya is offline
Old 09-08-2021 | 06:58 PM
SB
If you have 12vokt at small red/yellow at slave from ign when ign turned to start, then jump power across the two big studs on the remote solenoid snd if it cranks, it’s your solenoid.
if you don’t have power at smaller red/yellow from ign when key turned to start, ck its power at neutral safety switch in shifter snd at ign switch.
SB is offline
packinair
Swap Shop
10
07-16-2008 09:34 AM
jdub
6
04-13-2007 06:40 AM
Jerry B
5
06-14-2006 08:31 PM
seahawk
12
04-29-2004 02:21 AM
