Mercury seawater/fuel pump >
Old 01-02-2013 | 01:16 PM
  #81
Dean Ferry's Avatar
Veteran: Air Force
Originally Posted by TWIN-SPINS
dean ,the pin looks like it has to come out from the side of the housing,,,to me it looks like you woulds have to grind some of the housing out of the way ,in order to get a straight shot at the pin,,is this what you see also???
TS,
That's the way it kinda looks to me... I will talk with BF tonight as to how he did it.
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 01-03-2013 | 09:27 AM
  #82
Originally Posted by pantera232
What electric pump did you use? i put a holly red in mine but wouldnt suck fuel..
The Mallory 4140M has 16" of lift, so you can keep it out of the bilge.
ThisIsLivin is offline
Old 01-03-2013 | 09:28 AM
  #83
Originally Posted by Precision
http://www.cvproducts.com/ProdDet.aspx?PN=SPIN-MP-2630
Just another option. I'm a CV dealer if anyone wants real world pricing let me know.
PM me
Old 01-03-2013 | 11:20 AM
  #84
Kelly O's Avatar
Originally Posted by Dean Ferry
TS,
Dean
Dean,
If your 600's are 06's, check with Merc about if yours fall into the serial number range where the mechanical pumps get updated. Was told by Merc Racing tech the early 600's had pumps that should be swapped to the current part number.
Those mechanical pumps are the least expensive part of the whole fuel system and can cause issues further into the system, I would just put two new pumps on.
Kelly O is offline
Old 01-03-2013 | 12:31 PM
  #85
Dean Ferry's Avatar
Veteran: Air Force
Originally Posted by Kelly O
Dean,
Kelly,
thanks for the info, I'll check into it.
Dean
Old 01-07-2013 | 06:18 AM
  #86
Dean Ferry's Avatar
Veteran: Air Force
Ordered (2) new fuel pumps of Friday, should be here this week. Once I get them installed and the 388 is running again, I will experiment on trying to rebuild the old 1's.
Old 05-16-2013 | 04:22 AM
  #87
What do you do with the overflow or vent hose when you do the Holley upgrade?
Twisted tatum is offline
alecsammy
1
10-15-2008 07:10 AM
BillR
27
08-10-2008 11:31 PM
SED70
8
03-31-2008 03:15 PM
BillR
4
02-06-2007 03:23 PM
BeakBoater35
4
08-29-2005 08:33 AM
