525efi
Old 07-31-2007 | 08:35 PM
Default 525efi
Hi
we have a 2003 525efi. After we run it the coolant overflow tank is spurting out the cap. We thought it was just overfilled but we removed the coolant twice now to the half tank level and still have the problem. Raw water is getting in. Any idea where to look first?
sd11856g is offline
Old 07-31-2007 | 08:38 PM
monstaaa's Avatar
whats your engine water temp?
monstaaa is offline
Old 07-31-2007 | 09:01 PM
Hole in the heat exchanger?
Darrell.
DMOORE is offline
Old 08-01-2007 | 12:35 PM
148 degrees
sd11856g is offline
Old 08-01-2007 | 05:37 PM
monstaaa's Avatar
raw wwater pressure?
monstaaa is offline
Old 08-01-2007 | 09:16 PM
about 38-40psi at wot. It was running 45-48psi we trimmed down the low water pick up on the hull. We do not use the pick up on the drive. this is a SVL race boat
sd11856g is offline
Old 08-01-2007 | 09:34 PM
mtgbiker's Avatar
to much water pressure.
mtgbiker is offline
Old 08-01-2007 | 09:49 PM
UNSANE's Avatar
I talked to Merc about water pressure......35-38 at WOT is the norm and 40 is ok. I run about the same. I'd look at the heat exchanger as well as that should be the only place raw water and coolant are close to each other.
UNSANE is offline
Old 08-02-2007 | 11:39 AM
merc told me 38-40 was ok too. heat x is what I have been thinking also. I think I will try to blow some air into the water pick up see if the coolant tank bubles
sd11856g is offline
Strip Poker 388
7
04-08-2007 07:58 PM
Full Throttle 525
14
03-01-2005 10:17 PM
masher44
2
12-15-2004 03:18 PM
nitro/max
2
09-21-2003 10:08 PM
SLINGSHOT
06-21-2002 09:20 AM
