Water in bildge >
Water in bildge
Water in bildge
Old 08-06-2007 | 12:41 PM
JLAY's Avatar
Thumbs down Water in bildge
Last time i took the boat out i got enough water in the bildge to have the pump running off and on. After reading some threads i thought maybe the transom could be wet and soft.
(even though it has never stood in the water overnight and stays in a garage)Maybe because of its age. So i silconed around the perimeter of the OD real well. I took it out yesterday and it is still leaking. When i looked it seems like it is leaking right around the trim hoses and wires? What could be leaking? I felt the wood around the OD and it feels solid and not soft at all. Thanks in advance For the help!!!
P.S. It does have a block off plate but it is only a couple of years old.
JLAY is offline
Old 08-06-2007 | 03:05 PM
Bellows around drive shaft.
Shift cable
Trim wires
Block off Plate.
Did I miss anything
1BIGJIM is offline
Old 08-06-2007 | 03:41 PM
Most likely it is the shift cable boot..a real ***** to change..if you turn the wheel to the right it should stop leaking, turn to the left and it will pour in..that is shift cable boot.
Bajapred is offline
Old 08-07-2007 | 01:41 PM
JLAY's Avatar
Does anyone know if you can buy just the shift cable boot and not the whole setup?
JLAY is offline
Old 08-07-2007 | 01:58 PM
You can buy just the bellows..part# 74639A2 around $20
Bajapred is offline
klaw
9
09-02-2008 12:42 PM
Attack
Fountain
1
03-24-2005 09:11 AM
patricklhill
10-17-2004 10:45 AM
MiamiVice
17
10-13-2004 12:30 AM
