High Humidity >
High Humidity
High Humidity
Old 08-07-2007 | 10:13 AM
Default High Humidity
Does anyone elses performance fall off when it is in the high 90s -100 Degrees and high humidity, like silly humidity.
Went out the other night and could only pull 5200 with these props, normal is 5600-5700
Pro1 is offline
Old 08-07-2007 | 10:29 AM
Every motor loses hp in those conditions. Consider dyno standard corrected data which tweaks the output as if you were at 60* and 0% humidity. For instance, I dyno'd a motor last week at near 100* temps and high humidity. My standard corrected hp peak was 542, the actual raw data showed hp at 458.
jackhammer is offline
Strip Poker 388
07-26-2008 09:44 PM
sonic28
18
06-29-2007 07:54 AM
ccarloss
05-20-2003 02:24 PM
Cattitude
06-17-2002 07:45 PM
