700SCI Questions >
700SCI Questions
700SCI Questions
Old 05-08-2008 | 11:36 AM
KAAMA's Avatar
Originally Posted by pasquesi
Check out this video, if you haven't already seen it. There is CERTAINLY lag before the boost comes up.....
By the looks of it he also has his K-Planes/Trim Tabs burried too!
KAAMA is offline
Old 05-08-2008 | 01:38 PM
Originally Posted by Whipple Charged
Do you have # 6's or NXT's? By the way, I have a 33 as well.
NXT's. Yeah we actually know each other Dustin. Had a quad rotor motor.
B BOATER is offline
Old 05-08-2008 | 04:04 PM
Whipple Charged's Avatar
Email me if you get a chance, [email protected]. Curious what rake and diameter prop your running. I just went to the #6 prop shaft and installed some 37 pitch, 18deg props with 1.21 gears.
Dustin
Whipple Charged is offline
Old 05-08-2008 | 06:09 PM
see post in prop section mercury CNC
B BOATER is offline
Old 05-08-2008 | 08:27 PM
Email me if you get a chance, I'll fill you in on what I found. I'm running a 33', dual 1200hp engines, Imco SCT drives, with their new lower. I'd send you a PM, but it's not available.
Old 05-09-2008 | 07:08 AM
WildWarrior's Avatar
I'm not sure if this will help on anything other than a mercury #6 drive when spinning a large prop.
Without cavitation plate vent tubes we cant even get on plane.1.24 ratio #6 dry sumps 4 blade 37Px 17" Mercury cleavers methanol injected 565CI engines.
With vent tubes and very little throttle she spins right up to 5 grand and out of the water .
Again I cant say that it's not in the way Mercury has set up their 700s, but I cant imagine why they would program any intentional lag into their supercharged engines.
Good luck!
WildWarrior is offline
Old 05-09-2008 | 10:02 AM
Good luck!
The lag time is programmed in because you can order a 600 with an XR drive. Also, maybe the transmission in the NXT can't handle a full throttle holeshot of the 700? Then again, I may be talking right out of my fat white a s s!
pasquesi is offline
Old 05-09-2008 | 10:13 AM
Registered User
http://www.ilmor.com/710.html
Southocg is offline
Old 05-09-2008 | 01:00 PM
Still need a drive combo that wont break with the ilmors.
B BOATER is offline
Old 05-09-2008 | 01:34 PM
#6, or Arneson.
Darrell.
DMOORE is offline
