offset sterndrive >
offset sterndrive
offset sterndrive
Old 08-20-2007 | 07:02 PM
Originally Posted by tassie boy
standing behind the boat ,the sterndrive , engine and even the exhausts are 55mm to the left of the centre .it just don,t look right .cheers tassie boy
Does this mean, that if you were north of the equator, it would be offset to the right?
Regards.
Darrell.
DMOORE is offline
Old 08-21-2007 | 04:13 AM
fastlane40's Avatar
Guys speak slower and use simpler words he's from Tasmania you know
fastlane40 is offline
Old 08-21-2007 | 05:41 AM
thats not a bad bit of banter , coming from a thursday islander on his way home. but seriously this boat is 7.5 meters long but only 1900mm wide and 23 degree,s at the transom,if you were going to set a new sterndrive on it would you fit it on centre .cheers tassie boy
tassie boy is offline
Old 08-21-2007 | 06:33 AM
fastlane40's Avatar
Cool
Of course you would put it in the center.I couldn't imagine having it any other way.To have it offset would mean the motor being offset.Send me the pictures and i'll post them for you.csmazlin@tpg .com.au.Am i speaking to fast?
Old 08-21-2007 | 02:09 PM
I would center it. I'm sure that the offset was due to some experimentation to counteract the torque. You can do the same with rigging of heavy equipment and driver position.
Darrell.
DMOORE is offline
Old 08-21-2007 | 02:51 PM
i expect you guys are right and that would explain why it has sat unused for many years. not for much longer though. i,ll get the kids to put the photers on and to the bruvva in qld i,m still having trouble understanding you please type slower. cheers tassie boy
Old 08-22-2007 | 02:50 AM
Old 08-22-2007 | 07:39 PM
AIR TIME's Avatar
that omc drive will never hold up to 600hp there a dog up here, they break so much you can't give them away, save up do it right buy a bravo 1 set up used even. and center the drive or you will be going in circles on a slant used bravo parts run anywhere on here for 1000 to 2800 for used drive a gimbal asn will be a 1000 and up. there was a hole set up for 3000 last month. artie
AIR TIME is offline
Old 08-22-2007 | 08:01 PM
onesickpantera's Avatar
Depends on the year of the OMC drive. If it's a 1992 or newer real King Cobra it's a cone clutch model and just as strong or stronger than a Bravo.
onesickpantera is offline
Old 08-23-2007 | 02:49 AM
its the later model with the volvo type cone clutch with hyd steering.its a bloody huge thing compared to the penta. anyways thats all i,ve got so i,ll chuck it on with a couple of screws and see how it goes. i,ve also sent some pictures to fastlane40 and if we can keep him off the flagan he might put them on so youz can see what i mean. cheers tassie boy
