Lost ~17mph@WOT and ~10mph@3000RPM (cruise) Please any ideas? >
Old 08-28-2007 | 09:59 PM
Originally Posted by Payton
Congrats!!
Now take a level, level your boat on the trailer with the tongue jack, next place it on your tabs, make them as level as you can. Then put a mark beside your indicator. Do the same for your drives. a Magic Marker, touch up paint of a small peice of trim tape works well. That will help you to know where your drives and tabs are. Your tabs should be level with the bottom or just slightly up under average conditions.
Will do for the drive... my boat doesn't have indicators for the trim tabs though. When the tabs are all the way up, they are roughly in the position you describe.
-=Mike
TurbosRfun is offline
Old 08-28-2007 | 10:21 PM
Glad it turned out to be nothing.
Consider yourself very lucky. Most people's first boating screw up usually cost them a lots of money
Griff is offline
Old 08-28-2007 | 11:03 PM
Mike- Good deal, glad it ended up being nothing. Good luck and happy boating.
Jim
MOBILEMERCMAN is offline
Old 08-29-2007 | 06:34 AM
Donman's Avatar
From your pics, it looks like you have Bennet tabs. The switch on Bennets is opposite of what all other tab mfgs use.
I have Bennets on my boat, and I`m used to the switch on Livorsi, so I simply removed the switch assembly and turned it around.
Now, pushing the switch forward, raises the tab. Funny thing --- the LEFT switch operates the LEFT tab. It was criss-crossed before ...
Donman is offline
Old 08-29-2007 | 08:22 AM
Yeah... that's how mine is. If I push "Bow Down" on the right rocker switch, the left trim tab goes down... basically the right switch controls the left tab and the left switch controls the right tab. So maybe I was not so dumb, just confused a little? (grasping at straws here ) Now I'm wondering if there's a way to put indicators on the dash for the tabs I currently have... probably have to buy new tabs to do that.
-=Mike G.
Old 08-31-2007 | 12:05 PM
I dont know if you figured this out yet but as a separate subject from what you originally posted the warning buzzer is most likely low drive oil. I have a 91 aggressor and the only indicator I know of is low drive oil. It's pretty loud and anoying so since you have not mentioned it again I assume you took care of it but this is just FYI... Also, if your tabs were all the way down and your hatch was all the way up the reservoir for you bennett tabs will most likely be low. My reservoir was leaking so I pulled it off and apart and scraped all the old gasket off and put some gasket maker on there and resealed it and have had no problems since.
Good luck and maybe i'll see you out there this weekend...
aggressor91 is offline
jdub
8
08-13-2006 08:23 PM
liquid asset
27
07-09-2005 08:00 AM
fund razor
1
07-26-2004 07:59 AM
timucin
18
11-19-2002 11:23 AM
powerqrudy
4
05-30-2002 07:28 PM
