Setting points BBC >
Setting points BBC
Setting points BBC
Old 09-09-2007 | 06:57 PM
Full Force's Avatar
Default Setting points BBC
I was going to do a electronic ignition upgrade but decided for now to just do new points, 86 Baja with 400's
How do I set them up? I have done them in the past in a 20ft Sea Ray but never made sure they were perfect, I want this boat to run right, how do I set the dwell?? my dad has a old school dwell meter, just not sure what to look for.
Any info would help, thanks, Tim
Full Force is offline
Old 09-10-2007 | 12:04 AM
speedygonzalez's Avatar
Potronics makes a points module thats easy to install if you dont want to completly upgrade.
speedygonzalez is offline
Old 09-10-2007 | 12:49 AM
With the cap off,set the contact point of the points on one of the lobes of the dist.make sure the plastic/fiber is directly on top of the lobe.adjust the point now to the desired gap.usualy the thickness of a match book cover is about the norm.
JJONES is offline
Old 09-10-2007 | 03:12 AM
Feeler gauge:
New points .019
Used points .016
Dwell meter:
30 degrees
Don't forget lube.
Edward R. Cozzi is offline
Bilgerat
OPA/The Jersey Boyz
2
08-01-2008 08:01 AM
awsomethunder
2
06-15-2006 08:08 AM
TomR
13
08-27-2002 02:46 PM
