slop in bravo 1 >
slop in bravo 1
slop in bravo 1
Old 09-10-2007 | 02:52 PM
Default slop in bravo 1
I have a brand new boat with bravo 1 outdrive that has 1” or more slop left to right when you grab the drive and move it. Is this normal?
checkered is offline
Old 09-10-2007 | 05:55 PM
I would think a Bravo 1 that is "brand new", (no hours), on it should have less than 1" side to side play. Make sure all fittings are tight. You may need someone to move the steering wheel while you lean over the back seat and see if anything looks loose.
Edward R. Cozzi is offline
Old 09-11-2007 | 06:56 AM
sleeper_dave's Avatar
Where is the play? Does the boat have external hydraulic steering?
sleeper_dave is offline
Old 09-11-2007 | 07:10 AM
No hyd steering, just regular stock steering....Actually measured it last night...About 1/2" side to side, so 1/4" from center to left and center to right.....My boat dealer, who is an authorized merc sterndrive guy, says that's about normal? Just seemed to me that it should be SOLID with no movement at all when brand new, he says no, the slop is in the steering.
Old 09-11-2007 | 08:03 AM
Canada Jeff's Avatar
Once the engine fires up, and the steering system is energized, the slop is gone.
Canada Jeff is offline
Old 09-11-2007 | 08:12 AM
If it's just slop in the steering, it sounds like it's normal. If it's slop in any of the pins on the bellhousing or gimbal ring, then it's bad (but with a new boat that's pretty unlikely).
If the boat runs faster than 50 or so, look into some external hydraulic steering.
Old 09-11-2007 | 12:18 PM
1/2 inch side to side is about normal. I wouldn't be too concerned. From your first post I imagined much more.
Old 09-11-2007 | 01:34 PM
Brand new? If you have external hydraylic steering, there should be ZERO play. we rig boats with external steering. Never have end play of any kind.
John the Drive Man is offline
Old 09-11-2007 | 02:36 PM
See post #4 ......
Royal Flush
14
11-01-2007 01:11 PM
2112
5
01-26-2005 12:40 AM
p4-33
3
02-25-2004 07:09 AM
Mr Gadgets
08-20-2002 08:35 PM
EX20
7
04-09-2002 02:02 PM
