stock 400 cam upgrade question. >
Old 09-23-2007 | 10:35 AM
Full Force's Avatar
Default stock 400 cam upgrade question.
I have a 86 baja 320 with 400's, someone got rid of the q-jets and put on holley 750's, I now have to rebuild one engine due to a oil gauge line breaking last weekend, ran out of oil before I cought it, sounds like a spun rod bearing, I will be doing both engines so I know they are the same, I don't want to get crazy since I know it takes alot to make a 32 ft straight hull fast, I was going to get suggestions on what cam may be a nice "cheap" couple of hp with the stock heads, or should I leave them alone.
the engines were supposedly 420hp but it is tagged as 400's.
one engine was redone 2 yrs ago, that is the one they had the issue, I wonder is there a cam difference between the 400 and the 420? or is it just the carb and intake setup?
The rebuilt engine sounded like it had a tad more cam in it then the stock engine.
Another reason to do both is to make sure both have the same cam.
Full Force is offline
Old 09-23-2007 | 01:50 PM
400/420/525SC all have the same cam.
Its a Crane #132561.
Griff is offline
Old 09-23-2007 | 01:59 PM
Full Force's Avatar
Isn't a 525 a roller cam engine?
Old 09-23-2007 | 06:31 PM
the new 525 is a roller camed engine. Griffs post is refering to a 525sc wich was a 420 w/ 250 blowers. Up grade to roller cams if you can swing the cash it will be well worth it.
sschafee01@snet.net is offline
Old 09-23-2007 | 06:33 PM
Full Force's Avatar
I figured something like that, someone told me they were roller, I just assumed he meant roller rockers, they do have the gold roller rockers, I will do roller probably later, I did not want to do the engines this yaer but my oil line made me, I had alot of other things that needed to be done so these have to be redone on a budget, good thing I do all my own work!! All I need to pay for is machining/parts
Old 09-23-2007 | 08:11 PM
525SC uses the same flat tappet cam. It does have gold crane roller rockers as does a 420. Not sure about the 400 having roller rockers, but it should due to the cam lift.
BTW, a 525SC is a little more than a 420 with blower(its a weiand 177) on top. They were hand assembled and balanced at merc racing. Lower CR, inconnel valves, etc.
Griff is offline
Old 09-23-2007 | 08:14 PM
Full Force's Avatar
Mine have the roller rockers, I am not sure what valves are in it though.
Ken N
24
06-08-2007 05:55 PM
unbroken
1
05-26-2007 01:27 AM
Ken N
1
03-15-2007 09:42 PM
seabeach
14
12-29-2003 04:42 PM
seabeach
14
01-07-2003 08:47 AM
