Which way does oil go through the filter?  Center out, or outside into center? >
Old 10-02-2007 | 02:30 PM
zimm17's Avatar
Default Which way does oil go through the filter? Center out, or outside into center?
I'm installing my Dana marine remote oil filter block. I don't know which is the inlet and outlet. Does the oil need to go into the center of the filter, then to the outside? Or vice versa?
zimm17 is offline
Old 10-02-2007 | 02:50 PM
Outside in...
ghittner is offline
Old 10-02-2007 | 04:08 PM
PatriYacht's Avatar
Oil goes thru the outside of the filter and then back to the engine thru the center.
PatriYacht is offline
Old 10-02-2007 | 08:11 PM
zimm17's Avatar
Thanks. I had it backwards, but fixed it and got the plumbing routed correctly.
zimm17 is offline
Old 10-02-2007 | 08:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I always say out from the inside, in thru the outside.
US1 Fountain is offline
Old 10-02-2007 | 09:26 PM
Registered User
out of the motor
in to the motor
inside of the filter
the duke is offline
Old 10-03-2007 | 09:00 AM
PatriYacht's Avatar
I did it backwards one time. The filter had an anti drainback valve in it and it wouldn't allow a bit of oil past. I also have the bypass plugged. When I primed the engine, the drill would hardly turn. If I had started it, it would've beenjunk in 30 seconds.
302Sport
06-23-2008 03:48 PM
ActiveFun
1
07-31-2006 09:16 PM
JasonSmith
Baja
2
01-29-2006 08:42 PM
John B
2
09-13-2003 08:33 PM
