Hypereutectic w/ Boost >
Old 10-19-2007 | 04:10 PM
blue thunder's Avatar
Originally Posted by mrhorsepower1
.034 is way too wide. I have high boost pressure marine engines that I run ring end gaps alot tighter. If you want a sealed engine for along time .034 is not where you want to be. Hope this helps.Also the JE piston suggestion is a must!
It would be for most engines. That's why after the first season of running I had to tear them both down and open the ring gaps. With the kb silvolites the speced end gap for super charged marine big block is .038 which is about where I am at. The top ring is set high on the piston which is why the large gaps. I have near zero blowby after three seasons of hard running. Also, mathmatically speaking, an end gap of .028 or .038 is miniscule in relation to total piston clearance area. I like my gaps big.
BT
blue thunder is offline
KNOT-RIGHT
62
06-05-2022 08:03 AM
BadDog
10
05-19-2006 06:20 AM
QUIKDECISION
27
05-07-2005 04:35 PM
phughes69
6
02-14-2005 08:35 AM
Fountaineer
8
06-25-2004 06:49 PM
