420 HP cam specs?? >
420 HP cam specs??
420 HP cam specs??
Old 10-14-2007 | 01:46 PM
Full Force's Avatar
Default 420 HP cam specs??
I was looking to find out what the cam specs are on 420's, are there any worth while cams availible for it to make more power and not go roller?
what is a HP500 cam speced at?
Full Force is offline
Old 10-14-2007 | 03:15 PM
rmbuilder's Avatar
MarineKinetics
245 Limited,
420 Flat Tappet Hydraulic
298*/306/ @ .005"
228*/236* @ .050"
.312"/.324" Lobe Lift
.530"/.551" Lift Valve
114* +5*
HP 500 Hydraulic Roller
284*/292* @ .004"
222*/230* @ .050"
.339"/.352" Lobe Lift
.576"/.598" Lift valve
110* +5*
Bob
rmbuilder is offline
Old 10-14-2007 | 03:34 PM
Full Force's Avatar
So the HP500 has more lift less duration? I figured both specs would be higher then the 420.
Old 10-15-2007 | 01:22 AM
The 420 cam is a flat tappet. Crane #132561.
The 500hp cams are roller cams.
You might be able to gain a little with a custom grind in a flat tappet, but probably not enough gain to make the change worth it.
Griff is offline
Old 10-15-2007 | 04:58 AM
Full Force's Avatar
I knew the 500 was a roller, I was wondering if I could get close to the specs with a flat tappet, I will just keep what I have for now, I will do a roller conversion later maybe, then change cams.
Old 10-15-2007 | 12:08 PM
The design is totally different on flat tappets and rollers. Rollers have much steeper ramps on the lobes. You can't do that on flat tappets because of the way the lifters slide on the lobes. Thus on flat tappets, when you increase lift significantly, the duration goes up as well.
Griff is offline
delsol
11
04-04-2006 06:41 PM
lost2a6
11
08-28-2005 06:10 AM
redfountain420s
6
04-25-2005 07:13 AM
ragtop409
8
08-11-2004 01:43 AM
ursus
5
06-27-2002 07:27 PM
