bravo 1 speedo question >
Old 10-26-2007 | 08:57 PM
Default bravo 1 speedo question
i have a bravo 1 out drive on my 502 mpi,when i bought the boat it had a after market speedo called a medallion sport ,well i hit something and it broke it off,so i went to the dealer and they said they did not make it anymore,so my question would be ???does the bravo 1 outdrive have a speedo built in to the unit,? can i just take the hose off medallion and put it on bravo unit?i found a hose with a srew in it around the inside of outdrive area,i think thats where i would hook up stock speedo?and a another question would be ,why would some one disconect the stock speedo and go with after market and drill holes in boat to mount unit?please help me with this problemo,thanks always don
scarabrun is offline
Old 10-27-2007 | 05:31 AM
Look at the leading edge of the lower unit. You will find a small hole there, that is the speedo pickup. Blow into the hole and see if air comes out of hose you found. It may be clogged. If so do a search in this section. You will find instructions on clearing. Basically involves drilling it out (without losing the drill bit in the pickup) to remove any debris that has become trapped inside.
BadDog is offline
Old 10-27-2007 | 10:55 AM
Registered User
Just get a gps speedo. The bravo speedo's are worthless and inaccurate.
320es is offline
Old 10-27-2007 | 03:46 PM
offthefront's Avatar
Fix the speedo ..... its pretty close ....not perfect but close ..
I would blow compressed air back from the hose at the inner plate ... if you have to drill you can make the hole larger and change the speedo reading . m
offthefront is offline
Old 10-29-2007 | 08:03 AM
Air alone won't do it. Get an extra long 1/8" drill bit from a supply house that specializes in tools and supplies for machinists. Chuck that in a tap wrench and start digging out whatever is packed in there. It only takes a few minutes and doing it by hand you won't accidently ruin anything. With all the crap floating in the river I have to do this several times a year. Spray the bit with WD-40 after you are finished to keep it from rusting.
captnjak is offline
CasinoRunner
Baja
1
05-10-2008 10:23 PM
boatnuts
06-21-2007 01:36 PM
big jing 2
3
03-18-2007 03:50 PM
synack
1
04-30-2005 05:44 PM
klaw
2
07-07-2004 02:05 PM
