Bravo 1 has slop in p/s
I did buy my replacement gimbal ring from JR Marine. It looks very good and it went together with no problem. He actually takes your old piece on trade and sends you a re-man unit that he repairs in house. It will most likely need to be painted to look nice though.
Well, I am not sure I understand the connection between the gimbal ring as a holder of the outdrive on the one hand and the gimbal ring as a link in the steering system on the other hand. It is usually only the square pin that attaches the tiller arm to the gimbal ring that develops slop. Sometimes the U-bolt can be tightened, sometimes not. It is a really lousy design. If you get slop the gimbal ring as a holder of the outdrive may still be in perfect condition.
The gimbal ring where the upper swivel pin goes in is not square anymore. It will still move side to side or forward backward. Regardless if you change to full hydraulic or not it needs to be fixed. If there is slop in the tiller arm its because its moving around on the upper swivel pin(square bolt). Check out the pictures on the JRMARINE link in the previous post. Its easier looking at the pictures than trying to describe it.
