Any thoughts here on how to clean the clear plastic on todays vehicle headlights >
Old 10-29-2007 | 09:38 PM
G Man's Avatar
Default Any thoughts here on how to clean the clear plastic on todays vehicle headlights
thought someone on here would have a trick to clean the clear lens on todays vehicle headlights as they get foggish, and yellowish. etc .....
G Man is offline
Old 10-29-2007 | 09:47 PM
I use NOVUS plastic polish on my Jeep's soft windows to remove scratches. I've also used it on headlights and it works pretty well at cleaning them up. It's a 3 step system and can be bought online. Do a search on it.
Ryan00TJ is offline
Old 10-29-2007 | 10:05 PM
FITZ and a buffer is the way to go.
i did the lights from my stang like i was polishing alum on the bench grinder
styles is offline
Old 10-30-2007 | 03:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yep, Novus plastic polish. I started with the heavy cut to get most of the yellow off, then used the med to finish it off. Looked brand new when done and only took a few minutes doing by hand. Available at any plastic supplier, possibly even Lowes, hardware stores or such.
US1 Fountain is offline
Old 11-01-2007 | 01:42 PM
baja bailey's Avatar
I usually just machine glaze them...
baja bailey is offline
Old 11-01-2007 | 01:50 PM
Canada Jeff's Avatar
I bought a kit from Napa that was designed for renewing the clear lenses on vehicles. It worker great! Not buffing, just clean and then wipe on this chemical, let dry, and the cover looks good as new. I used it on a 03 or 04 Lexus ES300 .
Canada Jeff is offline
Old 11-01-2007 | 02:43 PM
fabricator's Avatar
Some of them get so crazed and hazy down here that we've had to wet sand the 'crusty' areas first with 600 grit to get to good plastic, and then polish them. There are quite a few good products (as mentioned) out there that will do job of polishing them after that.
fabricator is offline
Old 11-01-2007 | 05:18 PM
Full Force's Avatar
I usually wet sand them and use super duty compound, then polish, all with a buffer.
Full Force is offline
Old 11-01-2007 | 05:22 PM
Russ G's Avatar
The best way is to clean them really good with soap and water to remove all the dirt. Use 2 inch tape and out line the lights so you don't sand the grill, hood, fenders, and bumber. Then wet sand them starting with 800 grit sand paper then stepping the sand paper grit to 1500. Making sure the sand paper is very clean, it helps to put a few drops of soap in your water bucket to keep the sand paper from clogging up and cutting better. Clean the lights again and dry them off. Then with a high speed buffer buff them out using a heavy duty rubbing compond. Then clean them off again and buff then again using a finer compond. Finish up with a finishing polish. (non abrasive). Then you will have clear headlights again. Take your time and work as clean as you can. If you drop the sand paper clean it off very, very good or toss it and get a new piece. Its very easy to do with great results but you have to follow the steps.
Russ G is offline
Old 11-01-2007 | 07:16 PM
Thanks, I just bought some NOVUS off e-bay. Great price.
cobra marty is offline
