Transom soot >
Transom soot
Transom soot
Old 11-29-2007 | 06:04 AM
Originally Posted by Baja_man
Now what takes the soot of the transom? I have tried many products but take it all off?
I have had excellent results with Spectro XL-1 motorcycle wash. It also works well on removing brake dust from aluminum wheels.
Ken
minxguy is offline
Old 11-29-2007 | 02:29 PM
When we wash our boats it goes directly into our brackish lake, so I use Simple Green. It is biodegradeable and it seems to work fairly well. It does work well on the rest of the boat. Need to do a little scrubbing, but I can still see a slight stain on the back edge of the swim platform. I will probably have to buff it out with a lite compund type cleaner/polish.
gerritm is offline
Old 11-29-2007 | 07:33 PM
You would be supprised how well Method wipes work.
(I pick them up at office depot- believe it or not)
I tried them one day when I was in the shop goofing off.
My wife threw them out, so I dug them out of the trash can and figured I could use them for something in the shop.
Can't believe how good it works.
tomcei is offline
Old 11-30-2007 | 06:54 PM
The Menace's Avatar
Running too rich and you have black soot on the transom.
Run too lean and you burn holes in your pistons.
The former is better than the later.
Lean out the carb just a smidgeon.
The Menace is offline
Old 11-30-2007 | 07:08 PM
# 50 cleaner wax will get the soot off.
Back4More is offline
Old 11-30-2007 | 08:41 PM
Try 3-M Black Streak Remover or Mequiar's Black Streak Remover. Spray on and wipe; will take it right off
MC-BOYS is offline
Old 11-30-2007 | 09:30 PM
Use the 3M - I'm a shareholder
Dawg Gone is offline
Old 12-01-2007 | 06:46 PM
Ken
The Works tub and tile cleaner. You can get it at the Dollar Stores.
RBeyer is offline
Old 12-01-2007 | 08:41 PM
I have used West Marine hull cleaner which is some strong stuff it seems to take some off but not all. Is it possible for the soot to stain and never be removed?
Baja_man is offline
Old 05-25-2012 | 09:33 AM
Default 525 soot
Just joined the forum,have been reading for a while and finally joined so I can play while working.I have 525s in my Hallet 300 and the starbord motor soots the transom as well as dirties the oil more than port but the port motor does not.I have only run 91 octane in it and thought that was the problem but they are not both doing it.Sounds like I may have a bad O2 sensor also,both run great with no problems.Any input??I only use Amsoil Dominator oil in these.
RIPJIVE9311 is offline
BAJA WILL
04-23-2004 08:00 AM
poolshrk
04-07-2004 06:42 AM
bn
3
07-01-2003 07:44 PM
FBRONCO
1
05-17-2002 08:48 PM
CigDaze
23
02-01-2002 01:06 PM
