Can a 454 put out 650hp on 9.5:1 compression? >
Old 12-11-2007 | 01:34 PM
Keytime's Avatar
Default Can a 454 put out 650hp on 9.5:1 compression?
I'm looking at a 1988 38' Scarab that came with 420hp 454's. I'm told they're now putting out 650hp on 9.5:1 compression, bored out to 468 c.i.. I don't have all the engine details, although it's supposed to have LOTS of good parts, like Merlin heads, with no expense spared. It's a naturally-aspirated engine.
Is this possible? That seems like a LOT of hp for 9.5:1 compression.
Keytime is offline
Old 12-11-2007 | 01:57 PM
Registered User
Not without nitrous.
A moderately cammed 540/572 with a single dominator will.
Chris Sunkin is offline
Old 12-11-2007 | 02:39 PM
Elite Marine's Avatar
I had a similar set up with my old engine - 468, Dart Heads, Eagle Crank and rods, JE pistons (8.5:1) I think and a Procharger at 5 PSI - 638 HP.
I doubt those engines are close to 600HP. Another wishful owner.
If the engines are good and the boat runs, who cares what HP they are!!
Elite Marine is offline
Old 12-11-2007 | 03:02 PM
Panther's Avatar
Frank's Marine Service
Is it possible, yes.... Depends what parts... I've seen it done with 496 cubic inch engines.... Here's an example of what you need; 640 hp - 496
To get in the 600 range you would need some good aluminum heads and spin in the 6K rpm range.
Panther is offline
Old 12-11-2007 | 03:04 PM
t500hps's Avatar
21 and 42 footers
Built 540's out of 500EFI's. Dart heads, 9.7 compression, monoblade intake, big cam.....made 630HP at 5,100 rpms (was told carbs would have added about 35HP since I'm restricting airflow). Did make 700 ft/ TQ though.
t500hps is offline
Old 12-11-2007 | 03:18 PM
I used to own a Scarab that came with 454's also. Punched them to 468,big cams, heads ect. About 550hp. 650 can be done? , but.... it's going to be a very radical motor. Not very boat friendly. More of a strip motor. (still not too sure with 9.5-1).
Darrell.
DMOORE is offline
Old 12-11-2007 | 03:58 PM
On a 468 with 9.5:1 compression I have made 625 HP N/A . Your not going to achieve this with rect. port out of the box cylinder heads though. 550 HP with 308 Dart Iron Eagles/Pro 1 310's and a hyd. roller camshaft is very achievable.
mrhorsepower1 is offline
Old 12-11-2007 | 05:13 PM
It can be done.
Heads would need to be fully ported
850 - 900 Carb
cam would need to be around a 250 intake 260 exhaust set on a 114 lobe center and separation.
That combo would make 650 hp between 5500 - 6000 rpm on 9.5:1
The problem is your torque would peak around 5000 rpm. That's just waaaaay too much cam for a 468 on 9.5:1
With a crane 236/244 112 610/632 you could make 640hp with an 800 and fully ported heads. Thats still too much cam though.
Dumb question; is he sure about 650? 550 would be so much more reasonable and believable.
Dave F is offline
Old 12-11-2007 | 05:23 PM
Originally Posted by Dave F
It can be done.
850 - 900 Carb
??? Learn something new every day......
Old 12-11-2007 | 05:59 PM
Pwrbt33's Avatar
take that Dean.
Pwrbt33 is offline
