Why would Gil Manifolds crack? >
Old 12-23-2007 | 09:16 AM
I need one more set of Gils to complete the parts list to fit two BBCs into my 28' Checkmate. I found these on eBay, and wondered why they would crack in the first place?
Is this normal for Gils?Anybody had this happen to them?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
nwimbush is offline
Old 12-23-2007 | 09:47 AM
Michigan Mad Man
That is a common problem I have had several of our engines full of water over the years with cracked manifolds. If you look at that picture of the manifold you listed it was already repaired on the inside. It looks like bubble gum on there.
TylerCrockett is offline
Old 12-23-2007 | 10:37 AM
HiPerf2000's Avatar
I've seen more than one set of Gils fail in that area.
I would look for some stainless marine manifolds.
http://cgi.ebay.com/ebaymotors/STAIN...QQcmdZViewItem
HiPerf2000 is offline
Old 12-23-2007 | 11:55 AM
Thanks for the advice, but next time. I've invested in Gil for tails and one set already, otherwise I'd by these from Bad Enough.http://www.offshoreonly.com/forums/s...d.php?t=175626
Here in Ontario, the most common reason for cracking is frost - typically water left in the exhaust maifolds and freezes over the winter.
Do Gils (or any cast) have have a habit of cracking? What stress causes this? The weight of the risers vibrating?
nwimbush is offline
Old 12-23-2007 | 05:24 PM
Thunderstruck's Avatar
I had two manifolds crack/leak in that area. Don't know why. I still have two sets of old manifolds that I will part out for much less than the ebay add. Maybe shipping plus 100 or so. I will ship the best pair. If you are going to take a crap shoot on old Gils at least get them cheap. I bought new ones from Douglas marine. PM me.
Thunderstruck is offline
Old 12-23-2007 | 07:25 PM
PM away to Thunder - thanks. Merry Christmas.
nwimbush is offline
Old 12-23-2007 | 11:59 PM
My Merc/Gil manifolds cracked in the same place.
Griff is offline
Old 12-24-2007 | 05:27 AM
Biggus's Avatar
I lost a motor in my old Fountain because of a failed Gil manifold. Cracked in the same place.
Biggus is offline
Old 12-24-2007 | 05:45 AM
Any idea why? And from the eBay posting it looks like the crack is on the engine side, running on a 45 angle down from the flange...
Must be the stress from vibrating those risers.. anybody ever braced the risers? Anybody cracked Gils while running the Silent Choice pipsqueak, snub risers?
Too bad, as they look like a good option for aftermarket marine exhaust. I'm still going ahead and installing them because of the parts I've already paid for, but I am disappointed they have this reputation.
You live and learn...
nwimbush is offline
Old 12-24-2007 | 06:33 AM
Payton's Avatar
Charter Member #927
I bought 2 sets used that had beenrun in salt. 1 cracked in the same spot the second year I ran them. I had it fixed and have had no more troubles in 3 years. Irun in fresh water.
I wonder if salt or fresh water makes a dif.
Payton is offline
