Overheating Problem >
Overheating Problem
Overheating Problem
Old 01-02-2008 | 07:18 PM
Don't know how you flush the motors. Some boats have a hose attachment to flush. Its a possible spot for air to leak in before intake pump. If impellers and thermostat are OK as well as everyones suggestions and problem persists maybe removing heat exchanger and flush both sides. Motors corrode and the heat exchanger will catch what ever is present. The only other place I know to check for sediment build up is the block drain plugs. Side thought , a collapsing intake hose will give you a fit.
MOBILEMERCMAN is offline
Old 01-03-2008 | 08:01 PM
Ok thanks Mobile. I just flush with the mouse ears over the intake holes on the bravos. Nothing as advanced as an inboard connection.
jez350 is offline
fastrrrr
6
06-22-2007 07:17 PM
kennyo
2
05-15-2007 01:56 AM
duksrule
06-17-2006 05:54 PM
georges
6
06-08-2005 07:07 PM
dragraceguy
1
08-30-2004 04:17 AM
