:cool-smiley-027:Pull the drive lube ujoints and the coupler tighten the gimbal ring change the gear lube ck the wear pads and ck the spedo hole ck shift for water and ck the shift and drive bellows at most. $200
Doesn't a standard drive service include pulling it to grease the u-joints, inspecting bellows and checking engine alignment in addition to the normal gear lube change, or does that fall under extra service?
If you are going to do it, do it. :) |
Originally Posted by US1 Fountain
(Post 2413895)
| All times are GMT -5. The time now is 06:58 AM. |
