B&M 174 on a 454 >
B&M 174 on a 454
B&M 174 on a 454
Old 01-29-2008 | 05:59 AM
Originally Posted by MILD THUNDER
I think the hawk 525's dynoed around 525HP using the iron gm heads, hyd flat tappet cams, and lower Compression, and the 174 blowers from what I gather.
I would like to think with the better flowing alum heads, little more compression, and a hydraulic roller cam with more lift and duration than the hawk 525 cam, should be worth a few ponies, no?
I would think a naturally aspirated version of the above build with alum heads and roller cam, would make close to 500HP? Didnt the HP450 run a hyd roller cam and gm heads to make 450HP@ the prop?
Correct on all points but one: Mercury always rate their HP engines as crank shaft horse power, probably due to the various drive configurations
Alex is offline
Vmax
5
12-03-2003 11:28 AM
duunoit
2
10-07-2003 07:50 PM
duunoit
4
09-26-2003 08:29 PM
duunoit
8
07-21-2003 02:41 AM
hammereab
03-16-2002 06:51 AM
