Need isntallation manual for B&M 174 >
Old 07-19-2003 | 08:04 AM
duunoit's Avatar
Default Need isntallation manual for B&M 174
Does anyone have an installation manual for a B&M 174 out there? If you have it in an electronic format and could email it that would be great. Thanks.
Chris
duunoit is offline
Old 07-19-2003 | 02:59 PM
I don't have any instructions, but what info are you looking for??? Its a pretty straight forward install.
Bolt on the intake
Bolt on the blower
Bolt on the tensioner (if its separate from the blower
Bolt on the lower crank pulley
Fill the gear lube to proper levels using sight holes
Bolt on the carb
Attach the belt
Test the set up
Griff is offline
Old 07-19-2003 | 08:10 PM
duunoit's Avatar
Default info...
Torque specs, that kind of thing...
duunoit is offline
Old 07-19-2003 | 08:45 PM
28SCARAB's Avatar
duunoit The blower shop has it on there web site www.theblowershop.com
28SCARAB is offline
Old 07-19-2003 | 11:22 PM
RLW
I sent you an e-mail.
Russ
RLW is offline
Old 07-20-2003 | 12:46 AM
duunoit,
I had one, I'll look and see. The Intake is torqued just like regular intake. When you bolt the blower on it's 10 ft.lbs. or 120 inch pounds. Criss-cross when you tighten and work up to 120. I always started at 40 in. lbs. then 80 then 120 turning the blower while tightening. Mine never got tight but a friends did and left it loose ind wear in a little then tightened up all the way.
Mike
goob is offline
Old 07-20-2003 | 07:29 AM
duunoit's Avatar
Default just about neighbors
goob,
I see that you live in Franklin. My dad just bought a house out there. It is near La Hacienda.
RLW said that he has a copy that he is going to email me but your more than welcome to email it to me also. Thanks.
Chris
duunoit is offline
Old 07-20-2003 | 05:27 PM
RLW
Chris, I need your mailing address so I may mail it to you via the post office/snail mail.
Russ
RLW is offline
Old 07-21-2003 | 02:41 AM
Chris, I live off the Goosecreek exit of 65. If you want e-mail me your number and I'll call you and talk to you. I think I still have a pully for a 174.
[email protected]
Mike
goob is offline
MILD THUNDER
10
01-29-2008 05:59 AM
Vmax
5
12-03-2003 11:28 AM
duunoit
2
10-07-2003 07:50 PM
duunoit
4
09-26-2003 08:29 PM
hammereab
03-16-2002 06:51 AM
