Cost of 454 to 540 upgrade? >
Old 02-02-2008 | 02:11 PM
  #81
KAAMA's Avatar
Originally Posted by redcorvetteman3
Hey guys been reading your threads great stuff!! I was wandering Can anyone build a reliable 496 from a stock 4bolt block using dart alm. heads 10.2 compression and still get 625 -650 hp @ 5000 rpm or so? I have a builder that claims he can, he is pretty well known in drag racing and he knows thers a big dif. in marine motors.I think he uses comp cams to guide him on cam selection.Im worried about reversion if its a big cam.Any thoughts? thanks
Here's something you might like to know. For example, many Chicago boaters (I know/heard of) have taken their offshore engines to some very good drag/car type guys and only end up very dissappointed.....heck, they even have a hard time finding a legit marine engine shop that is supposed to KNOW what they're doing and are just as bad as the car guys when it comes to building offshore engines and some of these guys are pretty deceptive.
Talk to 10X (Frank)...he can tell you of many horror stories about unsuspecting guys like you who have taken their stuff to the wrong people.
KAAMA is offline
Old 02-02-2008 | 02:23 PM
  #82
Originally Posted by 5050
By the way has your 35fontain ever ran since you bought it.
Trade that Biotch in on a SKATER instead of makin it run
Old 02-02-2008 | 02:43 PM
  #83
He could get there with a cam set up for wet exhaust, he will have to spin it around 5500. I would use ovals though, or a realy small square port like no bigger than 310. Use a tunnel ram with dual 600's. You would need a header and use a solid roller cam, but I think it would work.
I have an engine in the machine shop now. Maybe I will try it.
jeff1000man is offline
Old 02-02-2008 | 02:56 PM
  #84
jryan26's Avatar
Truie!
jryan26 is offline
Old 02-02-2008 | 02:58 PM
  #85
[QUOTE=jeff1000man;2430650]He could get there with a cam set up for wet exhaust, he will have to spin it around 5500. I would use ovals though, or a realy small square port like no bigger than 310. Use a tunnel ram with dual 600's. You would need a header and use a solid roller cam, but I think it would work.
no access to the Swap Shop ????? and wtf is going on with that ???? you better sign up and be a OSO advertiser and Beanish will like you again
Old 02-02-2008 | 03:19 PM
  #86
nocigarette's Avatar
Talking
I have though of duing that myself....With my cam a tunnel ram would work well......I am not a tuner one carb is enough for me.......
nocigarette is offline
Old 02-06-2008 | 08:50 PM
  #87
ok, so say that for whatever reason i scored a set of bigger motors in the 600 hp range.. What about drives now?? Arent bravo 1's rated to like 450 hp??
waterboy222 is offline
Old 02-06-2008 | 09:06 PM
  #88
[QUOTE=RunninHotRacing158;2430668]
I bet sales have slowed down because I was buying most of that cr ap anyway.
You know anyone that has a full 14-71 set up with the intercooler that I can bolt right on. Carbs arrestor, snout, pulleys, belts, EVERYTHING. A 10-71 would work also, but I would rather have the 14.
Old 02-06-2008 | 09:08 PM
  #89
Buy an extra and run the pizz out of them. I've seen them take some pretty good abuse.
Just service them and keep your eyes out for a deal on XR's
Or carry a 5/8 wrench in your pocket. JUST KIDDING
Old 02-07-2008 | 07:54 AM
  #90
KAAMA's Avatar
You don't need to sell your Bravo One drives. Either "Articfriends"/Smitty or "Mr. Gadgets"/Dick can take your existing Bravo One drive and make it into an XR drive by installing XR parts, blueprint the drive to the gearcase and even make it better/more reliable than getting a new XR out of the box.
KAAMA is offline
