Trim Tab motor assy. ? >
Old 02-01-2008 | 05:53 AM
DONZI's Avatar
Default Trim Tab motor assy. ?
Are the Trim Tab complete motor/hyd's assy. and the Outdrive motor/hyd's trim motor assy. interchangeable ?
Meaning, can you use a Mercruiser outdrive trim motor complete set-up for K planes appl.?
2001 Mercruiser motor/hyd. assy for K-planes.
Thank you for your replies !
DONZI is offline
Old 02-01-2008 | 04:00 PM
DONZI's Avatar
These pumps for K planes ?
DONZI is offline
Old 02-01-2008 | 05:02 PM
Full Force's Avatar
I have the same question.. kinda, everythign I have seen tells me you can use them on either.
Full Force is offline
Old 02-01-2008 | 06:11 PM
on a outdrive green wire is up...on tabs green wire is down...
open87 is offline
Old 02-02-2008 | 05:27 AM
I'm using them for my tabs. Open 72 is right, you have to reverse them, I just ran the hydraulic lines up to the down port on the tab. The only difference is that the drive pump runs the tabs REAL fast- I only bump the tab rocker switch lightly to get all the movement I want, takes a little different technique.
Nova 26 is offline
Old 02-02-2008 | 09:45 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Correct.. But be careful on some of the newer stuff. There are some pumps that are high psi & some that are low psi hi volume. They will both move the plane but they would move at different speeds depending on the pump.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 02-03-2008 | 12:48 AM
sunchaser796's Avatar
Trim Tab Pumps run higher pressure
sunchaser796 is offline
Old 02-03-2008 | 09:13 AM
Mbam's Avatar
Offshoreonly Advertiser
Movin, blue is up (high pressure side) on a drive. I aways remember it by blue sky green grass
Mbam is offline
Old 02-03-2008 | 05:48 PM
jhiguy377's Avatar
you can vary the speed a bit by changing the viscosity of the hydraulic fluid - jeff
jhiguy377 is offline
Old 02-05-2008 | 08:32 PM
Boat Doctor's Avatar
Registered User
yes you can use the outdrive pumps for the k-planes changed mine last summer with no problems they are faster but imop they work better
Boat Doctor is offline
26sonic
04-30-2008 03:08 PM
FormulaOne
06-08-2007 01:11 PM
cbeastwood
Baja
1
05-14-2006 08:12 AM
26sonic
Sonic
8
05-12-2006 09:23 PM
raynman
General Racing Discussion
3
07-28-2003 06:58 AM
