System one oil filter.... pro/cons >
Old 02-08-2008 | 03:46 PM
Default System one oil filter.... pro/cons
Anyone running one of these? I just bought one because I change my oil so often. Any feedback.
kennyo is offline
Old 02-08-2008 | 06:24 PM
Kenny,
I try to talk my racer customers into using them. The big advantage that I see is that you can look at the filter everytime you change the oil ( after each race for some of them ) and "see" bearing problems before they cause major damage. In a marine application, if you notice any sudden change in oil pressure or temperature, the first thing I would do is open the filer and look for bearing material. Being able to clean the filter and reuse it makes it pretty cost effective if you do frequent oil changes.
I have not heard anything negative about them.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 02-11-2008 | 08:42 AM
Does anyone know the gpm flow or what micron it filters. I liked the fact its stainless and and not affected by moisture. Also is the spring loaded ball at the bottom a bypass? It doesn't seem very stiff. Thanks
kennyo is offline
Old 02-11-2008 | 09:06 AM
they are awesome for being able to wash them in the solvent tank and back to business , however we have sucked them pretty close to closed shut and you will want to buy the 15.oo part and eleminate the bybass so you are always filtering .... you may want to just switch to the HP 6 and no more worries
Old 02-12-2008 | 08:22 AM
Talking
Don't you have some nekid pics to post??
kennyo is offline
Old 02-12-2008 | 11:43 AM
I use pure power filters on my daytone my cars and harleys same type as system one in my opp. I do use system one oil pumps and love them
eliminatethis is offline
Old 02-13-2008 | 08:03 AM
We used to run them back in the 80's on my uncles race car. Then we discovered the Oberg filter and never turned back.
http://www.obergraceproducts.com/
Car Biz is offline
Old 03-31-2014 | 05:26 PM
so hows the filter working?
ballz2thewall is offline
Old 04-01-2014 | 08:02 AM
The o rings went bad last year so I quit using it. I agree that the oil gets dirty quicker for some reason..Bypass maybe, but I was changing it often due to fuel contamination. Probably saved double the price on filters though.
kennyo is offline
liquidcolors
Hustler
53
03-27-2008 07:45 PM
fantastixvoyage
4
10-23-2006 02:32 PM
Nova 26
0
03-13-2005 08:14 AM
Leathl_WS6
17
11-08-2004 10:37 AM
driveumhard
30
10-22-2004 04:57 PM
