small outboard Q? >
small outboard Q?
small outboard Q?
Old 01-06-2002 | 09:20 PM
mxz800's Avatar
Post small outboard Q?
i just bought a skiff with a 25hp evinrude it is still in the crate. do you have to winterize these motors when it gets to freezing or are they self draining like i have been told. seems like a pain in the a$$ to winterize each time since i want to use this for duck hunting in the winter thanx in advance. if this is the case i will just hunt off the checkmate and winterize that each time
mxz800 is offline
Old 01-06-2002 | 09:27 PM
Ted G's Avatar
Post
It does self-drain, just leave in the down position. As long as it runs once and a while you shouldn't have a problem with the carb gumming up either.
www.cbpba.com
Ted G is offline
Old 01-06-2002 | 09:59 PM
mxz800's Avatar
Post
thanks ted appreciate the help. i would like to join the cbpba could you email some info when you get a chance [email protected]
mxz800 is offline
Old 01-12-2002 | 11:00 PM
THE ANGRY WRENCH
Angry
Listen anyone who says you dont have to winterize an outboard is wrong!You should service engine including-gearlube-plugs-zincs-etc..It is very
important to "decarbinize"the outboard!if rings have carbin built up the piston rings can seize!Which is #1 cause of powerhead faliure!So think again about running your engine-decarbinize- fog with storing oil and run out of gas!
THE ANGRY WRENCH
Old 01-14-2002 | 06:00 PM
blue thunder's Avatar
Post
Yo head ball buster dude. I didn't see anyone mention not properly servicing an outboard. They were talking about winterizing. This typically refers to what needs antifreeze to prevent destruction of internals. Insptech is right on base... you are way off!
BT
blue thunder is offline
29scarab
7
10-16-2007 08:16 AM
Prater
Grand Lake/LOTO/E-Dock
4
08-19-2007 12:27 AM
Crazyhorse
01-17-2004 07:25 PM
GregP
08-12-2003 06:38 AM
