intercoolers and superchargers
I have 850s hp with superchargers with no intercoolers or chillers.I've heard salt water have a tendency to corrode the inside therefore going inside the motor causing a disaster.
What do you guys think????Any experience???
If the chillers are made of Cupronickel, then salt will not bother them.
Well I spoke with a reputable engine builder looking to upgrade for easy reliable horsepower and didnt give me a good vibe.He said i would have to be extremely carefull and even so I could be in trouble...I dont get it why then....
Well it seems your builder is in the minority on this. Most builders use innercoolers on blower engines. I think you have a higher risk of blowing the engine from detonation without a cooler then a water leak maybe causing an issue.
I have a set up to pressure test my intercoolers that is similar to the set up I use to pressure test my headers, Both can be used without removing the components from the motor! Not a bad practice (maybe a little over kill) to test at each oil change!
