a1000 fuel pump >
a1000 fuel pump
a1000 fuel pump
Old 03-22-2008 | 08:15 PM
Default a1000 fuel pump
on a merc with a 9 pin harness where would be the best place to get keyed power for my a1000 aeromotive pump, thanks
575cat is offline
Old 03-22-2008 | 08:34 PM
not trying to be a smart ass, but key on / key off and a 5 dollar test light work pretty good.
Unitek is offline
Old 03-22-2008 | 08:37 PM
jdnca1's Avatar
Smartazz....
jdnca1 is offline
Old 03-22-2008 | 08:47 PM
Default a1000 pump
would rather not splice into any wires ! are there any clean terminals,studs,coil ect
575cat is offline
Old 03-23-2008 | 12:12 AM
articfriends's Avatar
I don't know the best place to find keyed power on your particular harness but when you do find it use it to run a relay with 10 or 12 gauge wires coming from your main power supply to run your fuel pump so you don't suffer a voltage drop at wot,and if you want to be safe run it thru a hobbs switch so you don't have a fire if you get in some kind of wreck or accident or if something malfunctions if the key gets left on,Smitty
articfriends is offline
Old 03-23-2008 | 12:50 AM
The purple wire in your harness is a keyed 12 volt source. You can pick it up on the + side of the coil. If it is a factory carb motor, you can also get it from the choke or the alternator. It is purple at all of these locations. As Artic said, don't even attempt it without a relay. Let the relay do the work with 10 gauge wiring straight from the battery or alt.
Eddie
Young Performance is offline
Old 03-23-2008 | 08:52 AM
Registered User
If you're using a relay, why not get the switched source under the dash, from the switch itself?
Chris Sunkin is offline
Old 03-23-2008 | 11:54 AM
Then you have to run wires all the way back to the engine compartment from the dash. If you pick up the switched lead on the motor, you don't have to run wires very far. At least, that's my thinking.
Eddie
Old 03-23-2008 | 07:52 PM
Use a 5 pin 40 amp relay.
87a - 12v. from starter durning crank.
87 - 12v. fused from batt.
30 - to the fuel pump
85 - 12v. from ign
86 - goes to ground. I used a oil pressure switch also.
87 & 30 use #10 wire.
Noise Pollution is offline
BillR
11
07-29-2022 06:31 AM
jdub
7
03-26-2007 05:06 PM
cooltoys61
1
03-02-2004 05:25 AM
blown formula
3
04-25-2002 10:45 PM
