seawater pump/fuel pump question >
Old 03-23-2008 | 02:44 PM
Default seawater pump/fuel pump question
Has anyone ever taken one of these apart...I look at the schematic and cant figure out how to get the shaft out of the housing....am going to change bearings and seals if i can figure out how to get it apart...I have the impellar and housing off and have the fuel pump off also...I know i need to press the pulley off but ......then how does the shaft come out...Hopefully someone has done this or has a Merc service manual #16 that can look and see and pass the info on to me...Thanks
SED70 is offline
Old 03-23-2008 | 05:31 PM
I'm in the process of doing mine. The service manual says to press off the (pulley) hub. Then puncture the front oil seal and pry from bearing housing. Remove the snap ring from under the seal and press out shaft from the back (impeller side).
IM me a fax no. or your e-mail and I will scan and send you the pages tomorrow out of the manual.
ciaoderhead is offline
Old 03-23-2008 | 05:36 PM
axapowell's Avatar
Where To
Remove the pulley first.
You have to make sure you get the snap-ring off before you press anything!!
Dave
Attached Thumbnails seawater pump/fuel pump question-19.png
axapowell is offline
Old 03-23-2008 | 07:52 PM
CIAODERHEAD....my email address is [email protected]ks for scanning the pages and sending them to me
SED70 is offline
Old 03-24-2008 | 09:36 PM
Sent this afternoon. good luck!
Old 03-25-2008 | 04:16 AM
Says to use Loctite 514 on the OD's of the seals..Am having a hard time finding 514....Where can i get it or is there a substitute
SED70 is offline
Old 03-27-2008 | 07:45 PM
Anyone know where to get the 514 loctite merc says to use when installing a seal...seems to be hard to find
SED70 is offline
Old 03-29-2008 | 08:17 PM
I looked on their website and in McMaster Carr. I don't see it listed. There is a 5140, may be a missprint. Call your local Merc dealear and see what they use or call the Merc tech line.
Old 03-31-2008 | 03:15 PM
txriverrat2001's Avatar
Red Loctite works fine.....
txriverrat2001 is offline
upstate31sonic
19
05-15-2011 09:01 AM
alecsammy
1
10-15-2008 07:10 AM
BillR
27
08-10-2008 11:31 PM
BillR
4
02-06-2007 03:23 PM
BeakBoater35
4
08-29-2005 08:33 AM
