Engine rebuilder near Toronto, Ontario >
Old 03-25-2008 | 10:52 AM
pullmytrigger...
Yup thats my house on Anderson! Just sold the donzi through some guys at pride marine. Now need the h2x repower and vinyl done! Where do you run usually? I have a cottage on Balsam...
H2X BOSS is offline
Old 03-25-2008 | 11:29 AM
Originally Posted by H2X BOSS
pullmytrigger...
Nice!.....I consider Bobcaygeon/Fenlon/Buckhorn to be my home water......been putting in at Dutch marine in Bridgenorth for like 10 yrs now.......spend equal time around Lagoon City/ Orillia/Big Chief.......Active can do the whole turn key thing your looking for.....
pullmytrigger is offline
Old 03-25-2008 | 11:34 AM
jayhawk261's Avatar
H2X, I don't know who you can use up there, but we just turned my 385hp 454 MAG MPI into a 501 hp beast. We used Tyler Crockett's camshaft, lifters, and had him re-flash the computer. Then we used a set of RHS aluminum heads. We went up in compression to about 9.6:1. The final numbers were 501hp and 535 ft*lb of torque. We used the stock fuel injection system after having the injectors cleaned and flowed. We did have to step up to an aeromotive fuel pump to keep up with the fuel demand. An additional or bigger oil cooler will be required also.
jayhawk261 is offline
Old 03-26-2008 | 12:01 AM
RedDog382's Avatar
Originally Posted by nocigarette
Come to michigan.....
Scorpion Racing Engines LLC
12119 Levan Rd
Livonia, MI 48150 Map
(734) 953-4225
I second this one. I have been very pleased with my re-fresh done by Frank and Phil. Definately worth giving them a call. Top notch customer service that extends after the check is cashed.
RedDog382 is offline
Old 03-26-2008 | 08:47 AM
Airpacker's Avatar
Hey guys , thanks for the suggestions, I talked to Bullet at the boat show, will phone active today. Looking for someone to do the complete rebuild and rigging. I just want to turn the key, and suprise some of my friends! The baja was quick when I bought her 8 years ago...
Any suggestions on how to achieve my HP goals would be great to, would like to keep efi and bravo for now..
thanks!
I have a 500efi intake, cam and crane gold roller rockers as well as the 500efi cool fuel pump,regulater,cooler and lines as left overs from my motor. 100 hrs on the valve train. Decent set of heads and you would proly make your numbers with ease.
Airpacker is offline
Old 03-26-2008 | 11:27 AM
Airpacker,
That sounds like the setup mike from active was talking about for my 454, before he mentioned a crate 572 he could do... If you could send me any more info as well as prices, that would be great! You could email to [email protected] if you prefer.
thanks
H2X BOSS is offline
Old 03-26-2008 | 12:49 PM
RBT
Active, have had 2 engines done my them.... excellent!
I have no personal experience with Bullet but have 2 close friends that have.... both were redone, one by Active the other by Speedmaster.
RT
RBT is offline
satisfactionII
7
01-03-2006 06:31 PM
1stINSTIGATOR
07-23-2003 08:44 PM
WHITE-DIAMONDS
07-07-2003 01:02 PM
SLINGSHOT
02-06-2003 02:48 PM
1stINSTIGATOR
20
12-26-2002 10:53 PM
