Merc Alarm system >
Merc Alarm system
Merc Alarm system
Old 03-25-2008 | 08:25 AM
Default Merc Alarm system
I switched from MPI to a carburetor. The alarm goes off from the time I turn the key untill it starts and gets oil pressure. There must have been a timmer in the ecu.
Is there a way to add a timmer or do I need a different alarm?
Any ideas?
Mike
Noise Pollution is offline
Old 03-25-2008 | 06:55 PM
My carb engines all had about 10-20 second delay before the alarm would sound with the key turned to on.
Griff is offline
Old 03-25-2008 | 07:49 PM
I added an alarm system (low oil pressure and over temp)to my carb Volvo Penta and used a solid state timer in the system, dialed it in to where it barely gets oil pressure when it starts. I can't recall where i found it (can look tomorrow) but this is similar.
http://search.digikey.com/scripts/Dk...?name=PB783-ND
Or from McMaster Carr
7268K11
Relay with Single-Timing Function on-Delay, 12 VDC, .1 to 10 Seconds
In stock at $46.40 Each
happy hours is offline
Old 03-25-2008 | 09:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Could just buy the alarm timer/buzzer from Merc. that is used on the carbed motors.
Boatfix has the unit for around $30
PT # 816492A14
US1 Fountain is offline
Old 03-25-2008 | 10:08 PM
PT # 816492A14
Thanks, I check it out.
Old 03-26-2008 | 08:25 AM
bcfountain's Avatar
Registered User
Default efi to carb?
what did you have to do to convert to a carb?did you have to re-wire or use a diffrent wiring harness?
bcfountain is offline
Old 03-26-2008 | 08:30 AM
I found a wire harness from an HP 500. I want to sell the fuel injection set up, so I didn't want to cut up a perfectly good harness.
schill
Beware and Stolen
1
11-23-2006 12:12 PM
Sydwayz
Active Thunder
8
05-24-2006 09:13 AM
tmthunder
4
09-12-2004 08:33 PM
dropthehammer
2
06-23-2004 07:48 AM
PhantomChaos
03-10-2003 01:04 PM
