Need Help
Old 03-29-2008 | 05:28 PM
Default Need Help
I just never cease to be amazed with the ammount of knolege that is on here....
I have an 86 Scarab Ninja with TRS drives..... I have just noticed when I went to clean the drives for painting Both
have cracks around the gearcase bullet.... looks like salt water corrosion has expanded the housing.
My questions ..... are lower housings still available?
If not which of the speedmaster lowers will bolt on?
Thanking everone in advance Ed
inxs01 is offline
Old 03-29-2008 | 05:38 PM
Registered User
Housings are a tough find.
Forget SSM II's- they're very rare and expensive when you do find them. Plus they tend to be more fragile than the TRS.
Chris Sunkin is offline
Old 03-31-2008 | 05:09 AM
Can I use a set of #3's with my transom brackets if I can find a deal on a set?
inxs01 is offline
Old 03-31-2008 | 05:19 AM
nocigarette's Avatar
If i remember right a 3 will interchange with a 4 and 5 but a trs you can only use a old 2....Trs are tough old drives....The parts can be found.....Post some pics of that scarab those were one of my favorites...
nocigarette is offline
Old 03-31-2008 | 06:36 AM
Pwrbt33's Avatar
Post pictures if you can. Are you sure you dont have nose cones and they are coming loose from saltwater getting up behind them?
Pwrbt33 is offline
Old 03-31-2008 | 06:39 AM
Mbam's Avatar
Offshoreonly Advertiser
Yes, new housings are still available, we normally keep them on the shelf.
http://www.mercruiserparts.com/Show_...SING+%28TRS%29
Mbam is offline
Old 03-31-2008 | 08:05 AM
Registered User
Speedmaster III's have a completely different mounting hole and the X dimension (drive length) is different. Not an easy swap. Props for the III are much more expensive as well.
Old 03-31-2008 | 07:53 PM
I just upgraded my membership now I just need to figure out how to attach a photo....
I've been working on her for about six months and seem to be making some progress.
Took her out on the water for the first time last Saturday and was pleasantly supprised.
inxs01 is offline
Old 03-31-2008 | 07:55 PM
Default woops wong picture
I'll try again
inxs01 is offline
