Changing trim pump tank question >
Old 03-29-2008 | 06:32 PM
Donzi John's Avatar
Default Changing trim pump tank question
I need to replace the tank for my power trim pump. Can this be as simple as removing and replacing just the tank itself? Do I need to remove the hydraulic lines etc. or can it be done just by unbolting the current tank and installing a new one? I haven't messed with this before and I'm wondering how big a job it will be. Thanks for any advice...
Donzi John is offline
Old 03-29-2008 | 06:36 PM
Outdrive1's Avatar
Masher touches my
It's as easy as unbolting the unit from the floor, and unbolting the tank and replacing it with a new one. The older models have a bolt in the bottom, the new ones just have the four screws holding the tank to the pump on the top side.
Outdrive1 is offline
Old 03-29-2008 | 07:45 PM
Elite Marine's Avatar
If you want a nice billet one, let me know.
Kirk
Elite Marine is offline
Old 03-30-2008 | 05:45 PM
Donzi John's Avatar
Cool, I was hoping it would be that simple, thanks!
Old 04-02-2008 | 07:18 PM
Boat Doctor's Avatar
Registered User
you might want to suck the power trim fluid out of the tank before you take the bolt loose from the bottom of the tank or you will make a big mess
Boat Doctor is offline
Maritime_Eng
Drives and Lower Units
2
07-31-2008 11:58 AM
teaguecustommarine
New Products and Member Discounts
5
10-17-2007 12:43 PM
ratman
01-26-2006 07:48 PM
218diver
1
06-23-2004 11:50 AM
later
6
07-01-2003 08:31 AM
