Do I need a high torque starter??? >
Old 04-02-2008 | 12:23 PM
  #31
BY U BOY's Avatar
Originally Posted by jaxx 30
I have run an LS-7 454 with 12.5 compression and had no problem with a stock autozone/kragen starter. Check the juice getting to the starter. Pull the starter and have it tested. If worried about a gasket leak just pull a few plugs and look. I prefer the high torque mini starters just for weight reduction, size reduction, quick start up.
I have checked everthing from wires to plugs. I jumped the starter and nothing.Voltage is fine.I got a gear reduction starter yesterday that i'm putting on today.
BY U BOY is offline
Old 04-02-2008 | 02:45 PM
  #32
You could probably just put a hand crank on the front of that little sucker.
jeff1000man is offline
Old 04-02-2008 | 02:58 PM
  #33
BY U BOY's Avatar
Is that what the tranny you hired told you last night
BY U BOY is offline
Old 04-02-2008 | 02:59 PM
  #34
BY U BOY's Avatar
Is that blower motor going to be done for the shootout??
BY U BOY is offline
Old 04-02-2008 | 04:11 PM
  #35
Most of th parts should be here by the middle of next week, so I can get started on the machine work.
Old 04-03-2008 | 10:26 AM
  #36
Wobble's Avatar
SORE MEMBER
Patrick, go to Texas performance or competition sales and pick you up a hi-torque, they are a breeze to install and are much easier on the batteries.
Wobble is offline
Old 04-03-2008 | 10:50 AM
  #37
BY U BOY's Avatar
I got one yesterday but it was getting to late once i got the old one off. My old one has the staggered bolts and the new one has the straight bolt pattern. I was told it will work and i feel some bolt holes on the block that match up,just didn't have time to screw with it lastnight.
BY U BOY is offline
Old 04-03-2008 | 10:54 AM
  #38
Wobble's Avatar
SORE MEMBER
It will match up, should bolt straight up with stock oil pan, if you have offshore pan you may have to clock the starter a little.
Wobble is offline
Old 04-03-2008 | 09:47 PM
  #39
BY U BOY's Avatar
OK i haved been f'in with this for 3 hours now and have mounted it in every way possible.The bendix will not engage the fly wheel. Is there something i'm missing?Is it possible that the bendix doesn't extend as far as the stock one? Or is it not coming up high enough? I'm starting to get frustrated and not sure if i can take another min upsidedown
BY U BOY is offline
Old 04-04-2008 | 09:26 AM
  #40
Wobble's Avatar
SORE MEMBER
does your new starter have the same number of teeth as the old one? there are some options out there that wont work.
Wobble is offline
